intelliFire WiFi Module
HootOwl
2
Allen, TX
Hi all! Hoping to see if anyone would be able to help me determine if I could replace my gas logs intelliFire Plus IPI module with an intelliFire WiFi module.
My current gas log setup:
- Burner: Monessen GG24 Glow Getter Burner 24"
- Controller Module: intelliFire Plus IPI (LP)
Link to intelliFire WiFi module....
https://thefireplacesocial.com/all-about-the-intellifire-wi-fi-module/
Link to my log set....
https://www.monessenhearth.com/vent-free-gas-log-sets/moxie
The Glow Getter burner isnt listed the compatibility list, but the compatibility list also indicates that other burners may be compatible.
It would seem like an intelliFire WiFi controller module would likely be a perfect drop in replacement for an intelliFire Plus IPI module but i sure would like to hear what you all may have to say.
Thanks for your help!
Matt
Lennox65
Burning Hunk
Jan 29, 2021
203
New Hampshire
Matt
As far as I know, the WIFI module only works with the IFT module. This is from the link you provided: "You will need to have fireplace compatible with the IFT-WFM IntelliFire Wi-Fi Module installed. If your unit does not have that installed you will not be able to pair it with the IntelliFire® App. Products manufactured before Dec 1, 2019 require a retrofit kit."
HootOwl
2
Allen, TX
Ah. I see that now. I thought the wifi module and the IFT were one single module. Wifi is a "stab-on" module to the IFT. I need to see if my Monessen GG24 burner is compatible with the IFT module.
Appreciate the feedback.
Reactions: Lennox65
