I re-lit my Oslo tonight like I've done 100 times before. The stove was cold after letting this morning's fire burn out completely. I emptied the ash pan, loaded it up with some splits, kindling and fatwood, got the draft going the right way, and lit it with the side door open. Everything looked OK so I went downstairs to feed the rabbits.. I came up 5 minutes later and the fire was rolling so I closed the side door and went back downstairs. I came up 10 minutes later and the stove was an inferno- hotter and brighter than I've ever seen. The stove top and horizontal run of stove pipe through the thimble were both glowing. This was unusual, to say the least.
I cut the air back all the way and gave it a few minutes. The glowing subsided but the stove top temps kept rising and the fire was still rolling.. Then we heard a metallic BANG. Not the crack of a moisture pocket in a split popping, but the sound of metal snapping. We both ran to the stove and it looked OK. I didn't see any cracks, but I did find the culprit.. I had closed the ash door incorrectly. The handle side of the door was out of alignment with the catch.. The handle was tight and the door was closed, but the seals didn't line up leaving a gap of about 1/4" around the door. I'm not sure how I managed to do this, but I'll look out for it in the future.
So, now that the stove is back to a reasonable temp, I took a look around. I can't find anything obviously wrong- the secondary burn tubes look OK. I don't see an cracks in the bottom grate. Any ideas what might have made that bang? Are there any parts on the Oslo that are prone to breaking in an over-fire situation?
Thanks,
Josh
Thanks,
Josh
