This is my first post, so hello, eh? from Alberta. I'm going to begin installation of a hearth for an Intrepid II soon, and I find the installation manual a little vague at times. It states "For a new hearth, we recommend a noncombustible floor protector such as 1/4" non-asbestos mineral board or its equivalent, or 24 gauge sheet metal . . . the floor protector may be covered with a noncombustible decorative material if desired."
I plan on using ceramic tile or slate for the hearth, and I read this as if I will likely need both the board/metal and tile/slate. Am I reading this correctly, or is thick slate on my plywood flooring enough? I want to be really safe, but I'm not sure what the norm would be. I did search the forums for answers, but the usual answer to a similar question was "it depends on the stove." I do have a bottom heat panel/protector on the stove as well, if that helps.
Cheers,
Lance
Cheers,
Lance
