I have a theory that I believe must be correct, though I haven't been able to test it yet.
A lot of people have experienced this phenomena where they have a back draft down a cold flue that is so powerful that it pushes the smoke of a new fire back into the house. The thing is, if it was just stack effect created by the shape of the house and the cold, you would think that it would happen any time it's cold out since the shape of the house remains unchanged, all you need is cold weather and a cold chimney to initiate the effect, but the fact is it doesn't always happen with just those two circumstances. I have already confirmed that normal household exhaust vents don't have the power to create this effect. It's easy to test, simply turn all your vents on in the house when you have a cold stove and light the stove, they just don't create that effect to pull the smoke down out of a cold stove, not in my house anyway. So, there must be something else involved.
I believe this occasional strong back draft phenomena is caused by rapid change in the barometric pressure.
If your house has been sitting in a low pressure system for a while it will equalize to the low pressure outside, and when a strong high pressure system moves in rapidly it takes time for the house to adjust to the new outside pressure, and the only way that is going to happen is by air being forced into the house from every opening in the house, including the chimney flue. The greater the high pressure system, and the more rapidly it moves in, the stronger the air will flow down the flue. This is why opening the doors in the house will generally help, because it allows the pressure to equalize in the house faster and reduce the in rushing of air down the flue.
The only way I can prove if this theory is correct or not would be to have a recording barograph outside and wait until I get this phenomena of smoke billowing in the house from the cold stove when I'm trying to light it. If this only happens while I am experiencing a rapidly approaching strong high pressure system, then I'd be able to confirm this theory.
Anybody have one of those computer monitored weather stations?
