grommal said:
I have a relatively short, exterior, masonry chimney, with 8" clay liner. But, my Oslo seems very happy with it. I do sometimes have to start the draft if the weather isn't very cold, but once it's going the right way, it's happy.
Maybe this should be a separate question, but it ties in here.
I have an interior masonry chimney with a 7" clay liner. My local stove shop said it would be insufficient for my new Vermont Castings Vigilant, which requires a minimum of an 8" flue pipe. I don't get it since an 8" pipe has about 50 sq.in. of area while a 7" square liner has a 49 sq.in. area.
Does the square shape as opposed to a round pipe affect the draw?
Anyway, it seems to be working fine at this point. From what I've always understood, narrow flues increase velocity but obviously limit the amount of air that can travel up the flue. In my case, I have a very tall chimney (extends from the basement through two stories and then another 4' above the roof peak. I think the added velocity helps to move those gases up and out before they condense. I used to burn a lot of unseasoned wood in my old stove, mostly ash and cherry. I always got very little creosote because I followed my sweep's advice and ran the stove full blast for an hour every morning to get the chimney hot. He no longer yells at me about the creosote.
BTW, grommel, what do you mean by "start the draft"?
