Is an insulated liner always recommended?
LynneMcK
9
cobleskill
Looking into a Lopi wood burning insert. My supplier says I don’t need an insulated liner because the chimney has no exterior wall. Of course, once it goes above the roof, all walls are exterior. Thoughts?
That is not the determining factor. The clearance of the chimney structure from combustibles is. An interior chimney needs 2" clearance all the way up, an exterior chimney needs 1". If the interior chimney has 2" clearance then the clay liner also needs to be in good condition, no cracks, gaps, etc. If flawed, insulate the liner.
Yes it is always recommended. And almost aways needed to meet code
Reactions: all night moe
This site is so much more knowledgeable than the suppliers I’ve called. How do I find a dealer who knows all this stuff?
It’s tough. You probably won’t get a dealer with all the knowledge you’d hope for. I think “fact- checking” what dealers tell you on this site is a good plan. At the end of the day, their goal is financial.
In general, I think knowing as much background information as possible about your install is the best course of action.
I’ve found dealers who didn’t know their product well many times.
Now I just go in looking for a specific item. Get that item, and leave.
True! My local dealer sells, wood, gas (ng and propane) and electric stoves ZC fireplaces and inserts. BBQ's, smokers, outdoor fire pits and a bunch of other stuff.
Not to mention parts for all of the above and chimney parts and a ton of other stuff.
I prefer to know what I want before I call or visit.
I had an online company spec out a new flue system, stove pipe and chimney. Straight up through the one story ceiling/roof. They added on extra lengths of class A chimney pipe that I didn't need and a roof support that I didn't need. Added about $500- to their quote. I went looking somewhere else.
Well…. Many don’t. Some don’t care. Some are uninformed but willing to learn and do it right. Ask questions you know the answer to. When’s does a code require an insulated liner?
If on site ask
Does my chimney meet that code? (Look find the easiest place to verify your chimney does not meet code). After this you will get a sense if you think they are capable of doing the job. Breaking out a clay liner is hard work. Many people wouldn’t want to pay for that.
Reactions: Burnin Since 1989
Let the dealer or installer know that your insurance requires a code compliant installation, understanding that a lot of stove salespeople are not that well informed about installation. They job is to sell product.
Reactions: EbS-P
So the company says they will do an insulation wrapped SS liner for about $600 more. Sounds like they will just wrap the regular liner. Is that right, or are there actual liners that come insulated?
Some come pre-insulated and others do not and need to be wrapped with the insulation on site.
It could be either way. I typically just wrap it myself
