Was wanting to connect new wood stove up for dhw. I'm not sure it's worth it? I currently have a 50 gallon 10yr old lifetime guarantee electric hot water heater. I will have to purchase another tank approx $300-$350 ( don't want used one for fear of leaks or premature failure of some sort ), space lost in basement ( not a huge deal) 2 hwh stands $100. All plumbing including plumber (friend) guessing $200. Also small expansion tank. Guessing $100?? . Also the worry about extra things to leak, parts to fail. Also I'm not familiar with whole thing and not sure if tank will over heat while not in use and pop the relief valve. Was thinking it prob cost $500 a year to run current water heater. What do you think ? Is it worth it? I already have a coil in stove. This will be a gravity style system and if I'm correct only the 1 tank will be heated by stove , the main one can poss still use electric if not much water is being used so no drawl from tank being heated by stove? Also why do I need 2 tanks as recommended by stove company if only 1 is truly being heated by stove?
