Is there a difference between the Summit LE firebox and the Alderlea T6 LE firebox?
Derf Summerfreeze
36
Southern Ontario
Folks, I'm trying to sort out an anomaly. My 2022 T6 did not exhaust well until I modified the flame shield (see the thread on when did the flame shield sprout wings). Would someone who owns a Summit LE mind taking a measurement when they have time? Specifically I would like to know the distance from the top of the brick rail at the front of the stove to the underside of the top plate steel top. The reason I ask is because I have not found any particular post about the new low emissions Summit stoves having an exhaust restriction yet I thought both it and the T6 shared essentially the same firebox and new style flame shield. Thank-you, Derf
Calling @begreen as he has one of these two I believe.
They are identical inside. Look at the Alderlea innards parts list. They are Summit parts.
A little late to the party, but the Summit LE and the Alderlea T6 have the same fire box along with two other PE products.
[Hearth.com] Is there a difference between the Summit LE firebox and the Alderlea T6 LE  firebox?
Reactions: Derf Summerfreeze
