Is there a Max number of 90s that can be used with 4” pellet vent?
Quadrafire 52
13
Massachusetts
Using 4” ICC Pellet vent in basement installation. ( Quadrafire Mt Vernon AE)
Wanted to go up out and Up to Avoid any sooting on exterior of house . Is there a MAX number of 90s that you can use? ( I realize each 90 is equal to 5’ of pipe)
Thank You
Yes I have the same manual. Unless I’m missing something it doesn’t mention a MAX number of 45s you can use . The reason I ask is I was at at pellet stove dealer today and the guy told me the max number of 45’s allowed is 3 so I came back home and re read everything and still didn’t see it!
Maybe I Missed it !
but I figured I would throw that question out there in case I did !
Thank You
I don't think there is a max number of 45 you can use !
Just remember every 45 puts the equivalent of 3 ft. rise in the chimney
a90 is 5 ft. so use accordingly
The more 90’s you use will increase the turbulence of the exhaust and work your combustion blower harder
Reactions: SidecarFlip
It looks like if your total calculated equivalent feet is 30 or less, you should be fine. I did not see any limit on the number of 90's or 45's listed. The 3 90's in figure 13.1 is just an example.
