Hi I'm wondering if an exterior chimney run like this is allowed/feasible/realistic. I'd like to add a wood stove to our basement (strike 1). We already have an electric fireplace in the living room as wife didn't want wood in there this time. So putting a wood stove in the same room as an electric is kinda dumb. I know I won't get a whole lot of heat upstairs but downstairs gets cold too and this should help a bit plus give us back up heat if/when the power goes out. We are currently all electric (strike 2).
The diagram is the only realistic place to run the chimney short of going straight up into the 3 season deck which I don't really want to do. Thus the ~8' diagonal. I do plan to add an outside air kit as the house is fairly new and probably fairly tight. Question is how well will the pull be if I have to run the pipe like this? I would guess the entire rise from the top of the stove would be 20+ feet. I like the idea of a 30 degree wall pass through to eliminate 90s. This would leave a 30 at the stove, 30 to start the horizontal, 30 to start the vertical. Need a cleanout or 2 in there too, right? Basement and first floor ceiling are 9 feet. Figured I'd ask here for objective answers vs "yes you can" from dealer. Thanks!
