I know I have some flow reversal, when I was installing the thimble, I could feel the air coming down the chimney. I'm not sure if this is my problem though.
When my stove is off, and the chimney is cold, I get a campfire smell in the room. When the stove is on, and the flue is warm, the smell disappears.
I only burn the stove at night. Partially because our days are still warm, a bit of convenience, but mostly piece of mind. I'm still not comfortable leaving the stove lit when nobody is at home.
A few nights ago we had a wind advisory and I noticed a few downdrafts where smoke would puff out the seams in the (2) 45s in the pipe. Sometimes on a strong one I'd catch it coming out the intake damper. This has only happened that night, so it's probably wind related and not a reoccuring problem.
When the stove is off, I've started closing the intake damper so the smell will not enter the room. While this may have helped, it didn't stop all of it. Is flow reversal pushing this smell out of the joints in my pipe elbows? Should I seal them with gasket cement? I had been trying to avoid this incase I wanted to change the routing of my pipe off the stove. After the newspaper trick, I seem to have a pretty good starting draft so I may keep the pipe as it currently is.
Is there any way to stop this smell from entering the room? What about during the non heating season?
Thank you,
Matt
Thank you,
Matt
