Well my talley for the month is in,102 bags,Thats running 3 stoves.I hope February isn't anything like that.
I hope you correlate type use with average daily temperature 'cause if not your figures are useless.I started logging daily usage mainly to see what pellets worked better than others, etc... I am at an average of 2.65 tons per month with my Tarm unit....running a 70/30 mix of pellets/corn. It's way too expensive IMO. I either need to start making my own pellets or running the propane forced air furnaces to supplement on the cold days.
When it's 25 degrees and up, the system works great. Colder than that, and it chews through fuel like nobodies business....
Almost. Does that use factor apply to every pellet brand you've used?I burn 1.9 pounds per degree day. Does that satisfy you?
Most interested in which pellet worked best.F4 yes I have been recording average temperatures for each day as well.... So correct my general average use needs to include temperature as well.. I have it in a spreadsheet - I suppose I could work up a graph....It's been a while since I've done one but I'll figure it out again
I primarily use Lignetics. Like them pretty well especially for the price. I've experimented with several types but haven't seen enough difference to make me go hunting since I can get Lignetics reliably. I just got four bags of Somersets to try but the only place I can get them wants eight bucks a bag! Unless they melt my stove, cook my meals and are prettier than my wife there's no way!I had a local very small pellet maker doing some, and I am now running Lignetics... The local guy had finally got his formula to put out some heat, but his pellets have more ash than a store bought brand. Both seem to be working the same mixed with corn as far as heat output / consumption. IMO this boiler runs a lot better with a pellet/corn mix than with either straight pellets or straight corn
I burned 1.6 lbs/HDD this month.I burn 1.9 pounds per degree day. Does that satisfy you?
Thats insane...... 2.65 tons in a month in PA??? WTF? Most people up here, burn a ton or less per month, and its about 15*-18*F higher average temperatures here than PA...... Do you have windows and a roof in your home at all?I started logging daily usage mainly to see what pellets worked better than others, etc... I am at an average of 2.65 tons per month with my Tarm unit....running a 70/30 mix of pellets/corn. It's way too expensive IMO. I either need to start making my own pellets or running the propane forced air furnaces to supplement on the cold days.
