We upgraded from a Jotul F 602 to a 3cb over the summer. The Jotul 3 burned great all autumn and early winter with wood we had cut and seasoned. As we neared the end of our supply, we noticed it started to not burn as well. It takes longer to light and get going. Once it's going, the wood will have a nice flame for a little while, but then turns to a black block with a few red coals and tiny flames. We assumed it was because the wood wasn't as well seasoned. Then the glass got a crack in it. We saw that the glass had slipped in the brackets and assumed that caused the cracking. We replaced it with Jotul pyroceram from a local dealer. Then we bought some "seasoned" oak from a local guy. The same bad burn issue continues. It looks like nice wood, but perhaps it's not dry enough? THEN the glass cracked again. We returned to the local dealer and they think they had given us glass for a Jotul 3 F TD (due to price difference). This time we returned home with the correct glass, replaced the gaskets, and hoped for a better burn. But it is burning the same: long start time, good coals finally form, put logs in and they go -- the fire gets plenty hot -- but then turn black and don't let off as much heat. I have to stoke it frequently to keep it up and going and logs burning.
Do you think the glass breaking, wood, bad burn is all connected? Or is the glass a fluke and the wood just too wet? I can't find anyone else describing wood burning this way, so I'm at a loss.
