Hi everybody, I just want to throw out my stove design plan and see if I have my ducks in a row. Currently I have a prefab fireplace and plan on ripping that out. In its place I would like to put an alcove with heat shields on the walls and ceiling. The stove in question, the Jotul F 500, has really low protected ceiling clearances according to the manual and I think will work nicely in this space. So here are the pictures of my situation:
(broken image removed)
Above is my "before"
Above is my "after" design.
I want to lower the hearth and add the heat shields in the alcove. The floor would have brick tile on a concrete slab foundation. The alcove is 48" tall, 46" wide, and 24" deep. The clearance from the stop top to the ceiling is about 19". The heat shields are 1" off the wall and have 1" air gap on top and bottom. The ceiling has 2" air gap all around with 1" gap between stove pipe and shield.
Alcove clearances in manual:
Does this look all okay and legal?
![[Hearth.com] Jotul F 500 Alcove Install - Sanity Check [Hearth.com] Jotul F 500 Alcove Install - Sanity Check](https://www.hearth.com/talk/data/attachments/126/126474-0b04dcbeadf3304b75b7847e2034b4b7.jpg?hash=K3595RUHS5)
![[Hearth.com] Jotul F 500 Alcove Install - Sanity Check [Hearth.com] Jotul F 500 Alcove Install - Sanity Check](https://www.hearth.com/talk/data/attachments/126/126475-28d31197478b892ec5dcbf5adce34839.jpg?hash=h4RqYoc0Yn)
You actually created a 3D model of a Jotul 500! He is worthy.
