Hardcore said:
Thanks for the replies. I will see how it is burning this winter and then go from there. Does anyone know how much a new baffle costs? Also, when you take off the top of the stove, do you have to recement it?
I say contact your dealer to see if the vermiculite baffle will install where your iron baffles are, I'm not certain if it will but they should be able to find out. I think it will, as I was offered either when I went to replace my vermiculite baffle. My dealer told me to stick with vermiculite as the iron baffles warp and that is why they made the change.
There were three bolts (if I recall correctly) to loosen to remove the top, 2 accessed from the inside front of the stove and one accessed through the pipe opening at the rear. (the tough one to get to but not too terribly difficult)
Lift the top off, replace baffle, place top back on, tighten down, and done. There is no cement, there is a large rope gasket that seals the top and if you are careful not to damage it in any way it's an easy job.
The insulating blanket that lays on top the baffle is instrumental to the operation of the secondary burn system in the Oslo, it assists in keeping the temperatures up in the burn chamber so as to achieve clean burns....
Brad
