O
oldspark
Guest
He's running a probe (I think) are you or you external?HotCoals said:That's why for me the cat stove works better.Pete1983 said:I run around 800 flu temps as my stove has to when the afterburner is in use, but when it is not in use it runs around 650 flue. These temps are very common in newer EPA stoves and some need to run that hot in order to run properly. The stove on the other hand above 600 just waste fuel and heat as you have to load more often.
Pete
My pipe 18" up from my stove top(single wall) is never around 400..usually around 275-300..the last half of the burn closer to 250.
I like it like that.
Less going up the flue from the load but yet the cat cleans it up and really helps heat the house.
I burned the same stove for 24 years but without a cat...the old stove was not even half as good.
This thing is so easy to run..a few days is all it took for the basics.
Load it up,,burn hotter for maybe 20 mins till cat temp is up..flip the bypass..set the temp control and walk away for up to 24 hours or more in the shoulder..at least 12 in the deep freeze...16 hours avg.
:lol:
