King 5502m room fan inop
Krebs94
2
Illinois
I have a king 5502m and itll start up just fine but when it gets up to temp it will not kick on the room fan. Only way i can get it to turn on is if i hit the off button amd then it goes threw its shut down mode. I did the diagnostic mode and it shows the stove was 348Degrees
Do you know how to jump the low limit switch? If it does turn the conv fan on it should be shutting the stove down. It’s probably in the board. Try unplugging it and running power directly to it.
On the combustion exhaust there is a wire connected to exhaust make sure it's not lose or rusty etc. This runs your room fan.
