Hi all...
Ive got a Kozi KSH 120. been through half dozen combustion motors over last 8 years.
Stove is burning lazy. all new gaskets and foil taped motor housing seams as to ensure no air leaks.
In the 8 years I have run this stove (24/7), I've never had the convection blower out. That being said, if it is dirty or getting weak, would it adversely effect the Combustion?
It has been oiled annually and I generally burn 4 ton a year.
or.....Is there an upgraded combustion motor or impeller that can be used. The stock is 3000rpm...wondering if any benefit to bumping up to 3500 or so???
Thoughts fellas?
Thanks in advance!
-Rich
Thoughts fellas?
Thanks in advance!
-Rich
Sounds like a lot of exhaust fans ... Do you remove it after every ton to clean blades (& replace gasket as needed)? Blow out motor windings with compressed air to evict the dust bunnies? These might help you extend the life of the exhaust blower.
