Looking for some tips or advice for fine tuning my Kuuma Vapor Fire 100 during the transitional seasons. I installed the wood furnace in January 2018, and it has outperformed my expectations so far and I am extremely happy with its performance. I am still learning how to fine tune things in the transitional seasons. Some background. I have a 1900 sq. foot rancher with a full basement, so I am heating approximately 3800 sq feet. The furnace is attached to a 23’ (approx.) masonry interior chimney with a 6” stainless Rockford liner that was installed when I put the furnace in. I am also located in Maryland near Annapolis. For my alternate heat, I have a 4 ton heat pump.
When the days are in the low 40’s at day in mid 30’s at night, I am struggling to keep it from making the house too hot at night. I keep the thermostat at 72, and prefer that temp at all times. During the day when it is in the 40’s, I can feed 3-6(ish) logs at time and slow things down when things are too hot. I like to load around 9pm night. If I fill ½ full or more, I end up with the house being 74-75 degrees about 1-2 am in the morning and the wife and I can’t sleep with it that hot. If I load ¼ to ½ I sometimes end up having to reload at 3-4am. I want to be able to load around 9am and at least go to 5 am or so and keep the house at 71 or above. I can do it, but it seems I have to load just exact right amount to do this. My damper is set between 5-6, and probably a little closer to 6, and I have the heat output on the furnace on the lowest setting. I burn mix hardwoods, oak, hickory, locust and some cherry. In the transitional seasons I do mix some popular in there when I have some, which helps.
Looking for suggestions, or past experience on what other users are doing. I am thinking of adjusting my damper down to 3-4 during these times, but wanted some feedback first. When it gets down to the mid 30’s at night I notice the in-efficiency in my heat pump, so want to use wood furnace. In the 40’s or above, I am fine with the heat pump as I don’t notice it on my electric bill that much. When it’s colder than this, the wood furnace does a great job at keeping the house at a steady 72 at all times.
Looking for any advice or suggestions here from other users. The furnace is great, and I have zero complaints about it’s performance.
