Last year I noticed my damper was not opening as it should, so I loosened the damper spring a little bit and it worked fine. Just fired up the VF100 for the first time this year and noticed the damper was not opening as it should again. Loosened the spring adjustment a little more and it seems to be working though, I would like it to cycle a few days to verify. I still have a little more adjustment to loosen it if I need. Looking at the VF100 manual, it states to loosen the spring if it isn't opening as it should.
My question is, has anyone had to adjust the damper spring over the years. Furnace was installed in 2017 and I used the damper set as it came from the factory.
