![[Hearth.com] Large open sided concrete fireplace help [Hearth.com] Large open sided concrete fireplace help](https://www.hearth.com/talk/data/attachments/236/236736-67f763a34aef15b87813fb4e1ebb340e.jpg?hash=hMrL0obK-v)
![[Hearth.com] Large open sided concrete fireplace help [Hearth.com] Large open sided concrete fireplace help](https://www.hearth.com/talk/data/attachments/236/236737-1e8ba337f36bd64f7af0e64589f805db.jpg?hash=r2jeSXTrWL)
![[Hearth.com] Large open sided concrete fireplace help [Hearth.com] Large open sided concrete fireplace help](https://www.hearth.com/talk/data/attachments/236/236738-f9d499182c79e81e6ab423062796bdd5.jpg?hash=vzc4gvhoOy)
We are the proud new owners of a mountain home that we hope to make our primary residence this spring. Our house is at 9000’ in the mountains of Northern New Mexico and I have been reading up a lot of the great info this site has to offer.
Here’s the basics. 2100 sqft main level with a 700 sqft upstairs loft. Down stairs has a Superior BC42 fireplace and upstairs has a large concrete fireplace with a masonry brick interior. Both fireplace flues share a central chimney. I would like to be able to heat the entire house with wood as the current electric baseboard heaters are very expensive to run and propane would be the only alternative. There is no duct work in the home as there is no need for AC.
I think my best course of action would be to put a stove in the upstairs to handle that space alone and remove the downstairs fireplace to accept a large enough stove to handle all that space seperately.
The opening dimensions for the upstairs fireplace are 24 deep, 52 wide, 27 tall (more clearance above if needed). See pictures above.
1. Does anyone make a wide but short stove that would better match the dimensions for the upstairs stove? I really like what I’ve been reading about Blaze King for long burns as this would be needed for significant portions of the year, but I have found one that seems to fit the opening.
2. I’ve seen several older threads regarding the superior BC42, and it generally appears to be too short of an opening to get an insert installed of any meaningful size. It certainly doesn’t seem like i could find something that would fit and be able to really heat 2100 sqft. Is that still true today? Many of the threads I found were older. It would seem a full tear down and proper stove install is the proper course here, but any advice is much appreciated.
Thanks
Jake
