I don't use the ash pan at all on the princess I am using.Any one have any experience with these? and perhaps know what befits they add? (as in is it a big game changer?) .
. S.Z3820.BK Leg Ash Pan Kit
4. S.Z1726 / S.Z1726B Fresh Air Kit 4”/3”
Thank you this is very helpful.I don't use the ash pan at all on the princess I am using.
The fresh air kit can make a huge difference in some houses and none at all in other houses.
That depends upon many factors honestlyThank you this is very helpful.
My house is not super tight so i would guess that the intake would not do much for me.
Doesn’t warming the air going into the stove help the stove? I know cold air has more oxygen but from what i gather from many stove makers wanting to warm the air that warm air coming in would help?How much it would do depends on what you want it to do.
If it is for tightness, to avoid back drafting, then a not-so-tight home may indeed not benefit from an OAK.
If it is to not use warm air from your room to keep the fire going, that is then replaced by cold air leaking in thru gaps at doors and windows etc., making the farther rooms colder when the stove is on, then it might make a difference.
Putting one in Now be pretty simple seeing as I have everything open. Compared to after. Could you elaborate on what those factors are?That depends upon many factors honestly
The difference in temp between inside and outside air really isn't significant when you are talking about internal firebox temps well above 1000 degreesDoesn’t warming the air going into the stove help the stove? I know cold air has more oxygen but from what i gather from many stove makers wanting to warm the air that warm air coming in would help?
Where the house is leaky. If it is leaky high in the building envelope it can cause negative pressure issues lower in that envelope. That would make it more important. If you already have a high air turnover in the home and don't have negative pressure issues I don't think it would be of much benifit at all.Putting one in Now be pretty simple seeing as I have everything open. Compared to after. Could you elaborate on what those factors are?
It does have the same proportions. But in cold air I believe those molecules are mose densely packed. So you would get slightly more oxygen. But honestly I don't think there is enough difference with regards to a woodstove to really change anything. Now in a vehicle especially one that has forced induction it's a different storyCold air does not have more oxygen. It's still the same percentage of the molecules that is oxygen (vs nitrogen, CO2, and H2O, mostly).
And warm air does not make a whole lot of difference; to gauge these things one has to measure in the absolute temperature, i.e. Kelvins. Air right at freezing is 273 K. Air in your room is about 293 K. That is not a significant difference, and the air flow through the stove before it enters the firebox heats it up to I think around 600 K or so.
No, that is wrong. yes it's more packed. But once it reaches the fire, it's HOT. Meaning less densely packed. The total volume coming in is determined by the draft going out. If in the pipe into the firebox the air expands (as it does, getting hot), it does not matter what was there at the start (outside) opening of the air. The air in the pipe is not pushing MORE into the firebox.It does have the same proportions. But in cold air I believe those molecules are mose densely packed. So you would get slightly more oxygen. But honestly I don't think there is enough difference with regards to a woodstove to really change anything. Now in a vehicle especially one that has forced induction it's a different story
Fair enough. Like I said I didn't think it would make much of any difference in this case.No, that is
You could put a block of solid air at 1 Kelvin at the OAK outside, creating ultradense air when it sublimes (and is still very cold), and it would still be the same airflow thru the stove.
talking about temps I have dif ? that perhaps u guys might know why.No, that is
Not at all. Not only are wood exhaust temps higher normally but they have to be safe in the event of a chimney fire that can exceed 2000 degreestalking about temps I have dif ? that perhaps u guys might know why.
So the flue I had was suppose to be good for a gas flu but not for a wood stove wouldn't u want a better flu for gas fire places as lp and ng both burn FAR hotter then wood. also wouldn't u want a father safety cir around gas?
How is it that the flu temp is higher on wood that burns at max 1700 f were lp and ng both burn between 2800 and 3800 fNot at all. Not only are wood exhaust temps higher normally but they have to be safe in the event of a chimney fire that can exceed 2000 degrees
And by the looks to me like your old flue was for a prefab wood burning fireplace. But that isn't rated high enough for a woodstove either
Because lp and natural gas can extract much more of the heat with heat exchangers because it burns cleanly. And again chimney fires burn at roughly 2100 degrees.How is it that the flu temp is higher on wood that burns at max 1700 f were lp and ng both burn between 2800 and 3800 f
tyBecause lp and natural gas can extract much more of the heat with heat exchangers because it burns cleanly. And again chimney fires burn at roughly 2100 degrees.
We aren't talking about firebox temps we are talking about exhaust temps
