Location of test hole M55 Cast Help
RCR
29
Received a manometer this week and have the stove cranking on high at the moment. I have searched a ton of threads. I can only find the hole that exists on the side of the ash pan. Is this the best to test? I saw a post about a hole above the door but I can find or dont have one. Thanks in advance
the hole at the side of the ash pan will work fine or if you have a small diameter metal end for your hose you can shut the door on that
The owner's manual (pg. 9) states to to use 1/8 inch hole on the right side of the ash pan....so you should be all set.
your owners manual is you friend.read it from cover to cover
that is "the" place to test . vacuum off the vacuum switch line will give you an erroneous reading .
download the manual from enviro and this maybe ?is the stove where the manual is wrong about the side of the stove that the port (hole) is on :)
