looking for a thermostat for my Harman Accentra Insert
glenc0322
604
long Island NY
I am looking to install a thermostat for my stove I have a 2011 Harman Accentra Insert and this is the first year I am using Room Temp and like the heat output and think it saves on pellets by turning off I know there is a lot more use out of the Ignighter but think its worth it. I was Looking for someone that has installed one and which model number they used
I used the Napoleon F60 on my Timberwolf TPI35 Pellet Insert. Easy to hook up 2 wires from the receiver, put batteries in and sync remote to receiver and turn on. It cuts off after it gets 1 degree above setting and cuts on when it gets 1 degree below setting. Mine is set to go to low when it reaches the temperature and burns on low for 1 hour until it calls for more heat, If after the 1 hour it doesn't call for more heat, it will cut off.That will save the wear on your igniter.
