First time poster, long time stalker. Your forum has been a wealth of knowledge.
We have had out Pellet stove for going on 3 seasons now, making the smart move to leave oil (yuck!!).
It runs greats. We clean it moderately often, employ the leaf blower technique (awesome btw), and try to all around keep it maintained.
This unit has the ability to run a thermostat. And I know this is not the first time thermostat questions have been asked. The EnglanderStove site has very straight forward. I have 2 wires to attach on the pellet stove , removing the jumper of course. Then on the other end of the wire , the thermostat. I have a Honeywell RTH2510/RTH2410
The thermostat states it will work with pellets stoves. Instead of just ordering the one from Englander, I wanted on with backlight and programs. I followed Englander's site first time. It states one wire to W, the other to G, the set to Heatpump and Fan on. I did that. Nothing.
So the thinking comes in. I test the wire for continuity. All is well (New wire, but test it I did).
I then find a thread with a similar issue. Says the wiring should be W and Rh(R), no jumper. Ok, still non-functioning.
Now I can still go to the stove and just start it and it will start, just no stat. It has an on/off feature as well as a hi/low.
I go through the motions of unplug/plug then both down arrows. Its set to on/off mode.
I read maybe my wire may be to long for the stat. I test for milivolts, I get 24vac. Now I"m stumped.
Did I screw up the board? It will still run
