I am looking for a wood burning insert for my existing fireplace. The dimensions of the firebox are 35"W x 29-1/2"H x 25" D. In the back of the firebox the dimensions are 28"W and 19" H at which point the box slopes up and inward. I have about 34" from the opening of the firebox to the edge of the hearth and 15" from the top of the fireplace to the bottom of the mantle. My fireplace is located in the basement on the north east end of my home and my chimmney is taller than the peak of the roof and is all masonry with a 12" flue liner. I have an open stairway leading to the finished basement in the middle of my house. My home is approximately 1800 square feet not counting the basement which is 2/3 basement and 1/3 crawl space. I would guess the area of the basement is around 600 square feet. I also have about 200-250 square feet of loft as a loft above the main level which is included in the 1800 square feet. I want something that is going to be able to reduce my gas bill and be a source of heat when the power goes out at a minimum. If I could shut off the furnace all together that would be great. Lastly my wife is picky and wants something that is as close to flush with the opening as possible and maintains the look of a fireplace (large glass doors). We also would like as small a surround as possible (she doesn't like the large plain surrounds). So far of the stoves I have looked at she and I like the looks of the Hearthstone Clydesdale and the Jotul 550 insert. Any thoughts or suggestions would be appreciated. Thanks
Brandon Hill
Brandon Hill
