None of the big box stores carry it. I've called about a dozen drywall dealers and most haven't even heard of it. Where can I get my hands on some?
DonCT said:Yea, I finally got ahold of someone there. They do sell the Micore 300. Kinda pricey.
Oh well, I gotta try and think if I really need it, or if the Durock will hold the stove ok. Will 2 sheets of 1/2" Durock tacked with thinset do? It's gonna be set on metal stud framing.
DonCT said:None of the big box stores carry it. I've called about a dozen drywall dealers and most haven't even heard of it. Where can I get my hands on some?
DriftWood said:Hi
Read your stove manual, it will guide you through this process.
MICORE® Brand 300 is soft you can dent it with your thumbnail. Modulus of Rupture 350-450 lbs./sq. inch
Tensile Strength Parallel to surface 225-275 lbs./sq. inch
Perpendicular to surface 20-30 lbs./sq. inch.
r-value 1.09
http://www.acoustics.com/specs/USG_product/usg_spec.pdf#search='micore 300 spec'
MICORE® Brand 300 Board from USG is a superior substrate for fabric and vinyl-covered wall panels, office
dividers and tack boards. An excellent core for chalkboards, stove boards, and similar applications, MICORE Brand
300 Board offers outstanding resilience, superior machinability, high “k” factor, heavy density and highest surface hardness of any MICORE
½" Durock is hard. Indentation strength psi 1" dia. disc. @ 0.02" indent 2500 psi.
Uniform load psf (studs spaced 12" o.c.) 50 psf max.
(broken link removed to http://www.usg.com/USG_Marketing_Content/usg.com/web_files/Documents/Prod_Data_and_Submittal_Sheets/DrckCement_Board-Submittal_Sheet_CB399.pdf)
Composition and Materials DUROCK Cement Board is formed in a continuous process of aggregated portland cement slurry with polymercoated,
glass-fiber mesh completely encompassing edges, back and front surfaces. The edges are formed
smooth—patent No. 4,916,004. The ends are square cut.
Description
DUROCK® Brand Cement Board provides a smooth, sound base for glass and ceramic mosaics; ceramic and quarry
tile; lugged tile; and thin stone and thin brick. Suitable for application to wood or steel framing spaced 16 o.c. in
new construction and in remodeling. Board is ideal for use in partitions, walls, floors, soffits and ceilings in wet or
dry areas. It does not deteriorate in the presence of water so it is highly durable in high-moisture areas such as
baths, showers, kitchens and laundry rooms. Also adaptable for fences, fireplace fronts, mobile home skirting,
agricultural buildings, UL-listed wall shield/floor protectors, garage wainscoting and exterior finishes.
Limitations
A. DUROCK Cement Board is designed for positive or negative uniform loads up to 50 psf. For complete information
on the use of DUROCK panels in exterior systems, consult your USG sales representative.
B. Maximum stud spacing: 16" o.c. (24" o.c. for cavity shaft wall assembly); maximum allowable deflection, based
on stud properties only, L/360. Maximum fastener spacing: 8" o.c. for wood and steel framing; 6" o.c. for ceiling
applications.
C. Maximum dead load for ceiling system is 7.5 psf.
D. Steel framing must be 20-gauge or heavier.
E. Do not use drywall screws or drywall nails.
F. Do not use 5/16"DUROCK® Brand Underlayment for wall or ceiling applications.
G. Do not use DUROCK Cement Board with vinyl flooring.
My 2005 Hearthstone Heritage needs 1.2 r-value hearth pad. 5 sheets of ½" durock
OR
1 sheet of ½ " durock+1 sheet of ½ " MICORE® Brand 300 Board to cover the oak flooring in my house.
I put ½" micore 300 down first, then ½" durock and finished the top with stone tile.
Do have a air space the height of your metal framing?
Filling this gap with mineral wool is another way to boost the total R-value of your hearth pad.
1" mineral wool insulation = 3.12 R-value (ASHRAE Handbook of Fundamentals).
ansehnlich1 said:I'm going to do a hearth for a hearthstone phoenix and it's to be R-1.0
I'm laying 4 sheets of durock right on the subfloor and capping it with brick.
I say you could build up a raised base out of wood or metal studs, if you are worried about weight, put a 3/4 sheet of plywood on top, then 4 or 5 sheets of durock, that'll hold it for sure.
castiron said:ansehnlich1 said:I'm going to do a hearth for a hearthstone phoenix and it's to be R-1.0
Yes but in your case the 4 sheets do provide all the R-value you need regardless of what you put underneath. My question is this: say I need R= 2.9...how can i get away with, for example R=2 on top and then metal studs with insulation and air gaps below because directly above the stud, all I would have would be R=2 plus the metal below it and metal is a conductor....
