California is ready to drag the rest of the US into the EV age
Other states are likely to follow.
It’s a ramped target too. It will be interesting to see how the manufacturers respond and how other states handle the manufacturers response.Hydrogen is still in the running so it will be interesting what the fleet mix will be. Several other states (many in New England) have adopted CA standards in the past. Not so sure on this one unless someone solves the poor cold weather range of current batteries.![]()
Other states are likely to follow.www.theverge.com
Maybe for a fleets but ammonia is nasty. There were only a couple jobs on the farm I wasn’t allowed to do alone as a teenager and hooking and unhooking ammonia tanks was one of them ( the other was entering a not empty grain bin). Was the only task where I remember being drilled about my PPE. Probably wasn’t up to OSHA specs but for men whe would just jump into a cow pen and think nothing if it to make sure I had and always used gloves goggles and face shield and always worked on/from the windward side I’m not sure I would want to mess with with it as a fuel.If hydrogen is in the running, I would suggest NH3 + ICE is still in the running too. Easier handling and storage and energy density, at the cost of NOx cleanup. Could be an easier retrofit for heavier vehicles.
If the NH3 economy gets picked up for shipping fuels... it could then spill into the onshore market.
It’s different. Exposure has much more sever effects and it’s stored under pressure.But that is not different from gasoline...?
I think it’s a different class. No one puts on PPE to pump gas.Ok. But that's not an order of magnitude more. It's more, it's bad but not in "another class".
It’s use as a refrigerant in confined spaces means it kills people with regular frequency. Leaded gas just made us dumberRegarding the pressure; my dad (as many in that country) drives on lpg. Liquefied petroleum gas.. it's under pressure too. Not a big deal. (And cleaner than gasoline.)
I agree the consequences of inhaling ammonia may be harsher.
Yes, the gas stations there have special filling connectors, the lpg tank too. Technically it's a solved problem.But a liquid under pressure at room temps, not unlike propane (both are around 120 psi at RT). Similar inspection regimes would be required for tanks, and connecting/filling would need a special connector, like a propane filling station but with a purge. Not like filling a gasoline or diesel tank at all.
Maybe more common than thought. The ammonia fumes were so strong in the pit toilet at a popular state park I was at a couple of days ago, that it made my eyes tear up. There was no ventilation in there and on an 90º day it was cooking.Ammonia just isn’t a commonly handled product in the average persons life. One breath and it can just make you cough and feel like you can’t breathe. Get any on you and it just burns.
