Hi All - I've really enjoyed reading this forum and thought I'd tap into your knowledge before I pull the trigger on a new stove. A bit about my situation - I'm in northern Wisconsin, wood is our primary heat, we burn 4-5 full cords of oak per year, approximately 3000 sqft, well insulated house, 2 story open floor plan with open stair case to get the heat to the second floor. I have a 20 year old VC Defiant that is in need of a rebuild. I decided it was better to replace it. We prefer the look of a cast iron stove, so steel models are out.
I've looked at a number of stoves and spoken with several dealers. I've narrowed it down to a Lopi Cape Cod or BK Ashford 30. I've now had 3 dealers who sell both brands recommend the Lopi over the BK. All have said they believe the Lopi will do a better job heating a larger space. I'm more interested in heat output than long burn times. Winters are cold here and we need significant heat to keep up. As long as the stove will go overnight, I'm good. I don't have much need for a 24+ hour burn at low output.
I've seen several older threads, primarily from the first year or two after the cape cod came out, suggesting durability issues with the stove. The dealers I've spoken with all speak highly of the cape cod, say the issues have been addressed, and that their customers haven't had problems. Does anyone have more recent experience with this stove? Have the issues with the baffle/castings/glass been addressed? Also, I have an 8 inch stainless chimney pipe, straight shot, 35 feet. Both stoves are 6 inch models - will a 6 inch pipe connected to an 8 inch adapter at the ceiling above the stove provide adequate performance? I don't want to replace the chimney as its only 5 years old.
Thanks for your advice! This is hopefully a 20+ year investment and I want to make sure I get it right!
