Lopi - model FL
KSzonk
2
Does anyone know where I can find replacement blower fans? Lopi model FL
The house we purchased has the stove but the fans do not work. There is 2 fans on this unit.
Thank you
KSzonk
Thank you
KSzonk
KSzonk, are you sure it is the fans not working? Maybe it is the heat pop-off switch. I once thought my fan was a goner but found out I had to heat up the little temp switch in-between heat shield and stove. Worth a look-see.
A1Stoves.com ~ thanks, I will see if I can find one in our area.
Eater 309 ~I appreciate the idea, but yes I am sure it is the fans. There were 2 fans on this stove, one is missing - the other is froze up.
Oh, yeah that would be problem...:) Man those blowers are expensive for no more than what they are.
Good luck.
