So today I hooked up a SkyTech 5301p to my M55 insert, but it's not working right. It seems to only run the stove in low mode when hooked up and on either Auto/Off or Hi/Lo.
To set the stage, the hookup was very simple, unless I missed something.
The two black wires from the Skytech receiver were connected to the two red thermostat wires on the back of the M55. No preference was given to the black wires, as my understanding is that there is no polarity or anything, that they are interchangeable.
I made sure the receiver and the remote were paired properly (perhaps it lost the pairing, and the stove doesn't think a thermostat is even hooked up, so the default run mode is low when on a tstat control panel setting)? Another possibility, is that the receiver somehow isn't on the "remote" setting and is off. I doubt it, but I might have to slide it out and double check.
The problem is this - once I have it in Auto/Off or Hi/Lo mode, the stove has a small flame and low blower setting. Even if the thermostat shows it is calling for heat, it still never increases. The control panel does show a heat setting of 5 (how I set it) and that never seems to change.
According to the owners manual, when the stove is being controlled by a thermostat, the pellet fuel type (premium, normal, multi) light will flash. I get no flashing.
So in short, the Skytech seems to be doing nothing, and the stove is defaulting to a low run mode. When doing this, if I flip the switch to Manual, the stove blower immediately increases to the right level and the flame grows in size to the proper level. If I flip the switch back to Hi/Lo, the blower lowers and the flames dies off until it's small again. What gives?
1. Bad skytech thermostat possibly? I think unlikely, but you never know.
2. Maybe my pairing is broken, and I need to repair.
3. Maybe my receiver isn't in the "remote" setting.
4. Something else like a wiring hookup issue or something that I don't know about/can't think of?
Any help is appreciated. I was so excited to get the SkyTech thermostat hooked up, but it's not doing anything like it should be.
Thanks for the help.
