Super Awesome video, did you do that with a phone? Id like to do the same.
I have a Caddy, with Electric Furnace dual set up.
I can keep an 2000sq Ranch at 70 but the damper is open the whole time. set to just under a 1/4 inch.
I have my on/off set at 90/160.
It runs just about constituently all for about 4-5 hrs before needing loaded. 10 degrees out.
wood is 2yrs seasoned oak 15% ish
Good windows but still drafty, I think the roof is needs attention.
Camera in a GoPro, set to take picture at every 10sec. with USB connected to power.... and a fan to keep it cool from the heat of the furnace door :- )
I'm sure their is some App to do that on a phone, but you will need lot of memory or a way to transfer them on the fly in a computer. (20go of picture was needed for this video)
On/Off is set to 97/107F... that explain my constant cycling at half of the burn cycle... I can only set the "107" from 107 to 132, and the Off is always 10 degree less. To get to 160F, it would take a bit longer and i'm not sure it would start the blower again after a few hours... have you tried lowering this setting ?
Damper is always a bit open when closed, I have a drilled and tap for a screw in the damper door, It is open maybe 1/8 inch... don't know exactly, I played with the screw quite often and I didn't look at how open it is right now.
I found out that it is working MUCH better when you fill it up until there is no more space to add more split. The damper is full open for 20-30 minutes than close for most of the time, the TSTAT is set to 19C so it call for heat in the end of the burn cycle only.
In the morning or when I get back home, I use the electric 25kw to boost up temp to 20.5C and the caddy keep the house warm with wood only. It takes maybe 30 minutes for the electric heater to do that, from 18.5 to 20.5C.
For the other settings, the mode is Heat, which mean it start at speed #2, unless the plenum temp get higher than 140F and then blower speed up...
When I run wood only like the video, plenum temp never reach more than 120F, most of the time it will be around 110F or cycling...
I can reach 140F when wood is crossed with lot of space or when the Electric kick in and there is still coal.. or if I open the damper for a long time... but I prefer to boost with electric than eating wood and having to reload after 3 hours...
For chimney temp, when I reload, I put 2 or 3 split, then I wait for the chimney temp to be at least 200F before I load it full ( with coal already there ).
Then most of the time the chimey temp is at 160F, then somewhere around 120F when the furnace start cycling... I tried a controller to regulate the temperature to be not less than 150F to help creosote build up, but it was eating wood like hell... so i stopped worrying about creosote... we will see what happen next time I will clean it... (what you guys thinking ??)
Draft was at -0.07 and plenum at 0.22
House is 48 x 32 (exterior dimensions) one and a half with catherdal ceiling in the living room.. all windows are original '77 wood ( I use plastics pellicule on all windows upstair )... there was a Rodent rave party in the attic that i'm still taking care of when I have time... I'm in this house for almost 2 years now... Basement is uninsulated too...
