Me being cheap the Vermont Castings gas stove again!!
k0wtz
196
missouri
My log set in the Vermont Castings gas stove is sort of wearing out. Those logs need to set a certain way for the stove to operate correctly they wont any longer. Since these logs set in the fire they must get extremely hot is there a high heat cement I could use to hold these together in the correct stance?
I have used RTV black silicone & drywall screws (LONG ones) to repair ceramic fiber logs.
I have also spritzed them with Stove Bright Hi Temp paint to hide any flaws.
They look OK, & will hold up for a little while.
Make sure the paint is dry before you put em back in the flames,
or they will REALLY be burning...
Reactions: k0wtz
bob stupid me i figured out i had the main log setting the wrong way. reset it now everything is good. at 77 i am ready to become a stove man!!!
<<bob stupid me i figured out i had the main log setting the wrong way. reset it now everything is good. at 77 i am ready to become a stove man!!!>>
There's good reason to read those installation and operation manuals carefully.
Some gas fireplaces are quite picky about how the logs are installed, and they can be very non intuitive.
