Hi,
recently moved into a new home which was fitted with a morso 6143 which has a built in log storage unit as the base. I can see via Google that it is part of the morso 6100 range where I assume it’s the same stove but with different bases. Question is, we want to build a fire place around it and have the stove effectively inset into the wall. I would get a specialist to do this. But specifically I want to lose the log storage base as we will have a log storage built into the wall, design to be agreed as yet. So can I just remove the base and have it sat directly on a hearth, it would still be at pretty much the same height, though this is irrelevant to the question, or would I need to swap the base for maybe the 6140 base? Assuming bases are interchangeable and available to purchase separately. Hopefully someone is available to advise. Thank you, Richard
