just about everything i can find states to get the factory setting, i should turn the low and high all the way clockwise, then back them off 1 turn... they will both only turn 3/4 of a turn. i've seen the orange things referred to as limiter caps, is a certain point in one direction equivalent to 1 turn from the stop with the limiter cap? any insight on this will be appreciated. the saw is smoking a little bit (more than typically 2 cycle) and the chain is moving some at idle, so i wanted to tune it.
 is there a simple approach i've missed, or do you just have to jimmy it back in?
