Mt Vernon AE insert thermo couple Control board friction connector.
Truels2
6
02301
Good morning,
I went to replace my thermo couple on my Mt vernon Ae insert and noticed there was no Pressure tight friction connector on the control board ( not sure if previous owner lost it at some point). Does anyone know where i can buy a replacement as im having an issue locating it. I did plug the Thermo couple into the bare pins and it seems to make a tight fit (stove was not plugged in when i did this) Can i run it without the pressure connector or will that cause issues?
Thank you.
-Shawn
Mt Bob
4,422
park county montana
You are probably talking about the plastic piece that the end of the thermocouple wire platic side plugs into? Someone probably broke it off the board. You can use stove anyway. It can be hard to find those little things, but if you want to try, try Mouser and Digi-key.
Truels2
6
02301
Yes that is the piece im talking about. But from what iv gathered doing some research it is a pressure fit piece. Even the manual shows it as be able to come off the board. The two posts on the board are still attached and not damaged. I have the thermo couple plugged in but iv yet to power it up yet i wanted to make sure it wasnt going to cause any harm doing it this way.
Mt Bob
4,422
park county montana
Yes,sometimes they just snap in. If your wire teminals are snug when you pushed them on,you will be fine.But,in the long run,vibrations can affect it. Best you can do is go to those places I gave,and visually match it up,dimensions are listed also.Unless you have a friend in electronics,they would be more likely to find proper one faster. Or find an old control board to get one from.
Mt Bob
4,422
park county montana
Any kind of glue,just a small dab,metal from terminal to metal on connector. Some caulk never dries.
