My 025 is Cutting off!!
ReggieT
Burning Hunk
Aug 13, 2015
109
Birmingham, AL
My normally Steady Eddie Stihl 025 has been a bit problematic lately.
Was taking 10-12 pulls to get her fired up.
New air filter, fuel filter, fuel line, spark plug, running ethanol fuel, my Stihl Tech friend adjusted the carb and high and low...now I have to keep her throttled to cut...else she cuts out!:confused:
Any advice or fix it remedies?
Thanks
You mentioned new spark plug. Did you check that the gap is set correctly ? Should be fine when new but you never know if it got pushed in or something. If the gaps off depending on the degree it can cause running issues.
I find this curious and maybe something to pay attention to....
Its akin to "my friend fixed it, now it doesn't work";)
Is idle screw (TAS) in (CW) enough? Idle should be where chain almost moves.
Reactions: jatoxico
The word "impulse" is conspicuously absent here...
Yes...as in impulse line?...it was conspicuously omitted...probably much to my chagrin!==c
Yep. Definitely worth checking.
