Thanks & congrats on your new Ashford. I just saw your post, it looks like we both got our Blaze King this past Friday!Very nice place. All is nice : the cabin, the dog and for shure : the stove, it is just like my 30.2A. Hope to read your comments on how the stove works...
![[Hearth.com] My Ashford 30 was finally installed today. It is truly the cherry on top of my entire cabin build project. [Hearth.com] My Ashford 30 was finally installed today. It is truly the cherry on top of my entire cabin build project.](https://www.hearth.com/talk/data/attachments/336/336578-2fa1b4da47a0dc32d5dd13ad663176aa.jpg?hash=akvESHdfAY)
That's exactly the way these stoves are supposed to be run.Once the BK reached the catalyst zone, I closed the damper and turned down the thermostat dial. The flames died down and the logs smoldered to produced a nice gentle radiating warmth for most of the evening, I love it.
I'm sure I still have a ton to learn, but, would turning it up at the end of a burn be doing anything? (obviously depending on the temperature behind the stove) Wouldn't it be most likely that as the fuel is not available anymore the thermostat has already opened itself before the knob was touched?That's exactly the way these stoves are supposed to be run.
Some even say it's boring because the output is so constant that there's hardly a need to fiddle with it during the burn.
I basically only turn up the thermostat near the end of the burn, like half an hour before a reload, when only coals are left. It seems that the available range for the thermostat has reached it's limits then and heat output drops off, requiring the thermostat to be opened all the way.
You'd think that, but it's not entirely the case.Wouldn't it be most likely that as the fuel is not available anymore the thermostat has already opened itself before the knob was touched?
I kinda assumed that if it was calling for heat near the end of a burn it had already turned itself up?
That might be my difference, I have not turned mine more than halfway down yet...You'd think that, but it's not entirely the case.
Contributing to it is likely that I usually run the stove pretty much dialed down. The thermostat has a certain range of adjustment, but I think it just can't open "fully wide" when the knob is turned down, it just doesn't allow for that.
I'd have to watch it with the cover off, but the coals do get going quite some more, as @stoveliker said, when I set the thermostat to "open", so I suppose it does open up more then. But yes, since it's only coals at that stage, heat output doesn't increase all that much. But it's good for burning down the coals to get more space for the reload.
In practicality not really an issue, since the heat output only drops off when the burn is nearly done.
It really depends on the heat requirement you have. You're easily 1200 miles further north than I am ;-)I have not turned mine more than halfway down yet...
And surprisingly mild up here as well...It really depends on the heat requirement you have. You're easily 1200 miles further north than I am ;-)
