My door is making a squeaking noise when I open it
Graphite is a good idea.
Oil works too, it will harden with the heat, but usually stops the squeak.
Just be glad yours is welded on straight! If I could fix mine with a little anti-sieze I would be in heaven!
Jason
Graphite would work. If you want to try oil try synthetic.
I have used Never Seize and works well and can take the heat..
Ray
My door pins are peened on, so I keep a dripper of 3 in 1 oil in the woodbox.
heck our englander 30 the door pins keep workign their way out, i gotta hit them back down with the poker every other week.
If your pins are removable you can use a rub them with pencil ( I used a carpenters pencil) if you don't have any graphite of never size handy.
I used this on my air controls to reduce/eliminate some squeaking on my Lopi.
It's good up to 1K degrees.
[Hearth.com] My door is making a squeaking noise when I open it
Thanks for helping me out with the squeaking door problem.
In the past, I had use some marvels mystery oil lube but it did not last any longer than a few weeks and then it was back to the squeaking door. Does the oil burn off with high heat?
With the spray I am using... just dry graphite is left behind after the propellant has evaporated. I wouldn't spray around a hot stove and you might need to air out area a little if you spray inside but I didn't find it too bad. When I was spraying my air control I think the draft sucked in most of the fumes on the cold stove. If you can spray items outside that would be best.
EDIT: I can't speak for ultra high heat since temps around my air controls are no-where near the rated spec of this graphite spray. It hasn't worn off in a months of use though.
Thanks also on the reminder.
I used high temp anti seize that was in the garage.
As a side note: be careful opening and closing-the door banged against the wall because it moves so freely now!
Hey, Treacherous where did you get that can of High Heat Dry Graphite ? I like the high heat part.
The anti-seize sounds good too.
Yeah, when I lubricate my door you have to be careful it swings open so easy compared to before.
