I experienced my first "runaway fire" last night. I loaded up the Endeavor pretty full with some nice, dry oak. The stovetop was reading around 350F. Within a few minutes it was 400F, and I had a nice secondary starting, so I closed the bypass damper. At 450F, I close the air about halfway, and then at 500F I set it to the "sweet spot" where I get my best burn without choking out the fire (I can't seem to get more than 15 minutes of secondary with the air control fully closed). I waited about 15 minutes, then I went to bed around 10PM. At 11PM, I woke up and noticed that the room was very warm and that I could "smell" the warmth, in a sense. I immediately checked the stove, and it was maxed out around 850F. The surface itself never became red, but the fire brick in the baffle and the burn tubes were literally red hot. I shut the air down all the way and turned on the room's ceiling fan and set it for high.
I can't think of anything that was different last night save a 15 to 20mph wind. My setup is a double wall stove pipe going up for about a 5' run, then it's 8' of Class A through a bedroom corner, possibly another 1' through the attic, and finally 4'6" on the roof. This is a straight run, no offsets/elbows.
