I got a BIG down draft at 2AM that filled living room and now house smells like smoke. Windows have been open since it happened(luckily it's warm outside) but was wondering if any of you have any tricks to help further the smell.
pyro68 said:Delayed ignition is something normally related to a gas unit, but it is possible and fairly common in woodstoves w/ secondary burn tubes. The gases from the wood are being "re-burned" by introducing oxyegen through the burn tubes, if this process stops and gases build up in the stove, downdraft or just poor draft (chim not hot enough) the gases can ignite when the stove does pull air through the tubes. The stove fills with gas and ignites, sometimes even causing a small "boom" and smoke puffs out into the room. I've had it happen to my Leyden strong enough to lift the top load lid on the stove. I've tried several things and typically see this if it's not real cold out, and I turn the stove down before I have a hot enough fire going. Not a real good explanation, but maybe the phrase "something like that" applies here![]()
I'm wondering if the creator of this topic/inquiry has the recommended chimney cap with the spiral rotating thingie on the top which helps prevent downdrafts. I got 25ft of stainless steel stovepipe & that fancy cap installed for just a few hundred dollars. It's given me great peace of mind.[/quote]They Call Me Pete said:
  Only caution with a windbeater cap is they are designed to help in cases of WIND induced downdraft, probably would not help with just poor draft, neg. pressure ect.  If someone is not burning thier stove hot enough, they can get tremendous build up of  creosote on the cap very quickly.  Which reminds me, check the cap anyway, if enough creosote builds up on the cap that can block the draft enough to cause strange things to happen.We use essential cookies to make this site work, and optional cookies to enhance your experience.
