I have a Titan T 101 wood boiler integrated into my oil burner. Whenever I give it any kind of serious fire (more than two or three pieces of wood) it over pressurizes to 40 psi and starts releasing water into the wood box. Temperature runs consistently between 180 & 190 degrees and the auto damper seems to work fine. If I turn on the second floor heat zone the pressure drops to under thirty psi but only until that zone heats up to temperature and then the pressure problem starts all over again. I have only lived in the home four years and have always had this problem. I have had my oil furnace serviced including installing a new low pressure cut off switch and replaced the high pressure relief valve on the wood boiler. Chimney and wood boiler freshly cleaned two weeks ago and I dismantle and clean the wood boiler, accumulator and pipe every two weeks. (Not that any of that matters) Does it need more cold water somehow? Any help would be greatly appreciated.
