Mystery Wood Stove
olgreyhair
22
NE PA
Hello all. This stove is in our basement, was there when we bought the house. I have never burned it. It was connected to the oil burner chimney which is a no,no.
I am considering trying to use it to heat the pole barn. Seems like it can be disassembled and resealed and gasketed.
Does any body know what brand of stove it is?
Has no markings on the outside other than Made in USA cast into the lower back right corner of the stove. Other than that I am clue less.
Any ideas?? [Hearth.com] Mystery Wood Stove [Hearth.com] Mystery Wood Stove [Hearth.com] Mystery Wood Stove
Thanks for your time. G
Reactions: practicalolivia
looks like a combi jotul but not if it were made in the USA
Any ideas??View attachment 231216 View attachment 231217 View attachment 231218
I've seen people call it a Jotul Combifire, and it looks like it, but there seems to be several listed for the old ones and I don't know if they say made in the USA. I've very new at this also. I've only been doing research on stove for the last month or so. But, it's a brand to do further research on.
(broken link removed to https://jotul.com/us/guides/identify-your-old-j%C3%B8tul-product-and-user-manuals)
Thank you everyone. The dimensions match for a Jotul Combifire no. 4 B
Only thing I'm a bit disappointed about is the 8 inch flue requirement. Haven't built the chimney yet, but really wanted to stay with 6 inch due to cost and any future stove upgrades.
Thanks again
This may be a Jotul but I suspect it's a knockoff. The Jotul Combifire 4 has a pronounced dimpling texture. This one looks too smooth. Here is a combifire 4. If it's a Jotul there should be a UL tag on the rear. Look for any identifying numbers in the castings. And look for Made in Taiwan on the lower back.
Reactions: Easy Livin’ 3000
Hmmmm, suspicious. Maybe made in USA, China?
if you look at the manuals that was posted from the link all their stove say made in norway imported thru maine usa
definitely a knock off, i doesn't have the same shape to the castings. not to say it's a bad stove either. i had a combi knock off when in my twenty's it vented thru the top not back and had double doors with a spin dial air inlet on each door it did a great job
Yes, but that is not the same. The castings are done in Norway and Jotul is proud to identify them as such.
yup that was my point real jotul say made in norway
This is an American Seating knock off made briefly in 1976-78 of the Jotul Combi 4.
Little to NO info out on the web.
After 43 years, the axle on the rolling door assembly sheared off at one roller.
I am looking for parts diagram to figure out disassembly to weld broken axle.
ANY info would be helpful
Thanks
