First time posting, long time lurker. Great forum.
I had a napoleon 1402 installed 2 winters ago and up until this last spring have been very happy with it.
I started noticing towards the end of the last season fires would almost seemed choked when I closed the glass door. No more secondaries lighting off on the top of the stove. Also if I started a newspaper fire to get a draft going, as soon as I close the door, the fire would go from raging inferno to smoldering half burnt paper.
At first I assumed I needed a chimney clean in the worst way, but I just had the chimney swept last week and decided to start a test fire yesterday, same thing happened, smoldering mess once the door was shut.
Now I think it has to do with the intake, the napoleon's intake is somewhere on the bottom, im not sure if the secondary air shares the same intake as primary or not. But now i'm pretty convinced this is my issue. We have two cats so I suspect over the last couple years the bottom of the stove might look like the bottom of my refrigerator after a year, dander and fur clogging everything. Just a theory.
Has anyone here had this issue? Does anyone here have a good technique or have tried to clean the air passages on the inlet side of this stove? I thought about blowing compressed air down the primary air passage, but this wouldnt do much for the secondary passage (I assume).
As a last resort, ill decouple the stove from the flue pipe and tilt it back with a crowbar...not sure what I'll find under there. Also i notice this stove sits very low to the ground, you can just barely slide one of those cheap wood rulers they sell at home depot underneath it, should I elevate the stove a bit with some metal bar stock for better air flow?
Thank you.
Thank you.
