Looking to put a second stove in our basement. We have a large house about 1400-1500 first floor and 1000 second floor. We put a 1700 Enviro Venice insert in our fireplace in the family room (but not an open floor plan) so doing ok heating most of first floor but not moving much upstairs (still working on fan placement) - first year with stove so finally learning how to get it cruising at 500-550 versus turning the stove down too soon like most of us newbies do.
My question is we are working on finishing our basement (about another 1000 sq feet) that will be a large open room (but where we want to put the stove is opposite side of the house as current stove but in basement not on first floor like the insert). I have read a decent amount on here about basement installs but it will be a primary heat source for making the room functional and will be insulated walls as well. We are putting porcelain tile floor down and removing the insulation in between the basement ceiling and main level floor) to help with heating as well. Will keep basement door open with fans as well to help move heat. Probably won't cut new registers in floor for this.
Home Depot has just started its clearance on the Englander stove and have an opportunity to buy a new Napoleon 1900 (with door/ash pan) for very reasonable $1000-$1300. We will have to add a chimney for either one and they both take 6" flues). I am VERY attracted to the Woodstock Progressive hybrid but I can get a chimney in and stove for price of just the Woodstock stove.
So my question to all you guys is an opinion on which stove to get. We do also want to be able to use the basement as a game/activity room without totally being baked out but want to free myself from our heat pumps as much as possible (luckily upstairs has its own furnace/heat pump) so if i did need to supplement that its ok.
Is one stove more convective vs radiant? Looking for any insight into this! I know go for bigger stoves
esp where we have a LOT of windows and a late 1970's house that could always use more attic insulation (next spring) but at least has newer windows. Not 100% sure how tight it is, only been here a few months.
Also open to other sugeestions that might fit the bill as well OR if I should really just save up a few more pennies for the stove I am truly in love with (both looks and specs - if you think it would perform best for my situation) - if I left any details out (because it is definitely past my bedtime) just ask away!
Thanks!
Thanks!
