Napoleon npi45 insert HELP!
2002 Honda
3
michigan
Won't stay lit. Runs about an hour but puts itself out. Had a guy come diagnose it and everything was running fine mechanically with the stove while he was here but told me to sweep the chimney and that should solve my problem. Did all that but still doesn't run like it should problems are still there. How do I check for bad circuit board?
. Auger light blinks on for about 4 seconds and shuts off for about 2 seconds
the auger light sounds normal. Does it have the digital control with the two rows of lights? I have that stove. You can control the pellet feed and convection fan speed independantly of each other. It may be turning off because the convecton fan is running too fast and stove isn't staying hot enough. Try higher pellet feed or slower convection fan speed and see what happens.
Yes
Yes it is. Thank you I'll try tonight and let you know
