How is the alcove install working out? I'm looking to do something similar with an MF Fire Nova 2 freestanding stove. (The Nova 2 insert would require a custom front plate due to the size of the fireplace opening.) (I've also read all about the smoke rollout issue users have had with it.)
I have an all-masonry 1940's brick and stone fireplace (no mantel). Two years ago, I had the chimney rebuilt from the roof flashing up (approx 7'), a 16" steel liner installed with insulation, and the firebox rebuilt. Two years later, I realize an open-fire that vents through a 16" hole in winter is not ideal, nor is the post fire smell that permeates the house.
This is more for aesthetics and occasional use than a primary heat source, but the opportunity to capture heat instead of venting the entire house is very welcome. As is the EPA rating for general indoor and outdoor air quality.
I'm planning a DIY install with city inspection (I'll need a 6" x 20' steel liner, appliance connector, 20"x20" steel chase, chimney cap and 1/2" cement board to block heat from going up 16" liner).
![[Hearth.com] Need advice for woodstove in alcove [Hearth.com] Need advice for woodstove in alcove](https://www.hearth.com/talk/data/attachments/343/343126-1ba471f9129347323340c16b0a8325b8.jpg?hash=rzcVj0yTKV)
