Hi - I'm new to the site. Looking for some advice...Please see the attached pics. I currently have a Lennox/Marco prefab and I want to install the Hampton H300 freestanding woodstove with the short-leg conversion kit that I have already purchased.
I have received a few estimates and the plan is to vent my woodstove through the prefab by installing a new 5 1/2 or 6" insulated liner (approx. 25ft chimney). The prefab is a zero clearance with an 8" flue. My H300 has a rear vent plate and we would use a T / 90 degree to attach. I would also install a metal surround to cover the prefab.
My problem is my current brick hearth (which is on sub-floor, not cement) is not large enough to handle my woodstove. Also, the current brick hearth sits about 3" above the hardwoods, so even if it was large enough, I do not have the clearance (even with the short-leg kit) to vent into the existing prefab if my woodstove was sitting on the bricks.
My question: What options do I have to lower and extend my hearth? The boss (my wife) loves the look of the brick and white mantel, so I'm trying to do as little demo/construction as possible. Trying to keep it simple on a budget.
My initial thought was to remove the verticle and 1st horizontal row of bricks. Install a piece of Wonderboard or Durarock that would bring me flush with my hardwood floor, then install 1" thick marble or slate. The marble/slate would sit on the wonderboard/durarock and my hardwood floor. This would give me about a 2" drop for the clearance and still keep the woodstove fairly close to the prefab. I didn't want to have my woodstove sitting in the middle of the room! That is why I would remove a few layers of the existing brick hearth, instead of simply placing the marble/slate in front of the brick that is there now.
Would this work? Any other suggestions? Any help would be greatly appreciated. Thanks in advance.
