Some of you all may recognize me from a few years ago. For 14 years I heated my house in NY mostly with wood. First with the crappy, and probably dangerous Franklin style stove that came with the house and over priced unseasoned wood that I bought and ending up with a Woodstock Fireview and 3 plus years reserve of wood that I personally scrounged and processed, and all the support tools, trucks, tractors, etc. 2 years ago we gave it all up and moved to Las Vegas, NV. In case you all didn't know, it actually does get cold here in the high desert. Not bitterly cold, but the high 30s, very low humidity, and some wind can make for a chilly night in December thru March.
The house we bought is a "vintage", by Las Vegas standards 1982 split level with a nice big old fire place in the ground floor den. It has a gas burner in it, but the chimney sweep (trained in Chicago) that we had to the house yesterday says that the fireplace and chimney are "real" and capable of safely burning wood. He did suggest either removing or replacing the gas burner after this season as it is old and somewhat degraded from use. The sweep suggested we get a set of glass doors to improve efficiency and to have some sort of draft control. Kinda like the little sliders on the doors on my old Franklin stove. I have never really dealt with a traditional fireplace before and I know nothing about these doors or where to get them. Any suggestions or anything I should know when I shop? The opening is 36" wide by 24" high.
One other thing. Is is normal for the house to smell like burnt wood after using a fireplace? We almost never had smoke smell in the house with the crappy Franklin stove or the Fireview.
