I just ordered a Quadra-fire Mt Vernon E2 that will require a 40x40 hearth pad (corner). I like the look of the plain black steel hearth pads that seem to be only available in Europe. The only similar thing I can find is a Morso steel hearth plate, which works for appearance, but doesn't provide the 1.61 R value that I need. I am trying to decide if I can make one (unless anyone knows where I can buy one...). I would like it as thin as possible.
If I were to stack 2 pieces of 1/2 inch Micore 300 (R value 1.03), and then add the Morso steel pad on the top, would that be adequate? Do I need to add a layer of cement board to support the structure? How would I adhere the 3 (or 4) layers together?
I am not particularly handy...but looking to do this as cheaply as possible.
Thank you!
Thank you!
Even got a discount on the tile adhesive cuz it was an "opened package" at HD. Used grout caulk, and it was a super simple job!
